Temperature Control Light?
7374
Pittsburgh
Is there a suppossed to be a light in the dash for the fan/temp control in the dash on a 74 dart?
Thats a good question. As a general rule of thumb, if you ashtray has a light the heater control will have the same type fixture also. I f neither is lighted you can find the fixtures and install them. All ashtrays and heater controllers have provisions for the light fixtures.
Thanks. my ashtray does have a light, so I'm guessing the bulb is burned out. Just found time now to start replacing bulbs and such in the interior. It's the little things that make things look so much nicer.
