Terminator X for magnum engines
dusted
Creedmoor, NC
Saw this at the Moparty and talked to Holley about it. They released the 46re trans control at the show also. It’s a plug and play setup. Looking forward see people using this.
What is this? Step up from the Dominator? Sounds like "real money" to me..........
The LS terminator X has been out for a year now. Hemi wasn’t far behind. Basically less inputs/outputs version of the dominator and less cost. Lots of guys going very fast with this.
S word!!!! Wish this was out when I spent money on a spare HP ECU!!!!
I feel like I need to clarify that the Terminator X is a plug and play engine management system for the 5.2-5.9 magnum engines and will also control the transmisson (46re). Configurable for any magnum engine combo that you can imagine and utilize EFI.
The X max had the trans control. One would only need the Term X if wanting injection and to use a 904-727. The universal system is designed for Chevrolet and dodge factory port fuel injected engines like TPI or magnum, although it doesn’t specify. Holley had 2 on-site to show. The harness is already assembled and ready to go.
Nice! I wasn't aware Holley was doing this but I will be looking into it for my Dakota for sure.
