investigator
Updated pictures drivable but not Road ready. Engine bay pics
dash
Thanks for the advice it clears with the 2-inch air cleaner but not with the 3-inchBe aware with that air cleaner it doesn't have a drop. With that intake your might hit the hood unless you have a scoop or cowl. My 340 with a Weiand Stealth and Holley (nor spacer) the fins went into the hood insulation on my stock GTS hood.
Mancini sells a drop base for it.
Otherwise, keep up the good work!
Thank you it was my first time to paint. And tried to do most of the modifications like headlights and other electrical mods recommended on the site. It is a 390 horsepower 360 Magnum back by 727 with cope trans mods and a 83/4 and 355 gears.the engine bay looks really sweet. nice and clean
Don't know off hand mine is an old paper filament soon to be replaced with a K&N 2x14 inch. I have a 3 inch K&N but it's just a little too tall. I'll get back to you with a part number in a few minuteswhats the air cleaner part # for the 2 inch tall filter
E 3740 at Jegs $66 2 5/16 inches tall 14 inch diameter hope this helpswhats the air cleaner part # for the 2 inch tall filter
I will get a picture later the lid does not reach the outer edge of the air filter but seems perfectly fine as it's pressed down into the rubberand that will fit the mopar performance air cleaner??
Mine came with the engine when I bought it used so it is possible and has a different base on it but the top seals around the top of the filter it doesn't go all the way to the edge thoughand that will fit the mopar performance air cleaner??
Any pics yet?
Same combination here, looks a lot worse than yours, ....nice job.Thank you it was my first time to paint. And tried to do most of the modifications like headlights and other electrical mods recommended on the site. It is a 390 horsepower 360 Magnum back by 727 with cope trans mods and a 83/4 and 355 gears.
Thank you for the kind words and complimentSame combination here, looks a lot worse than yours, ....nice job.
Holley blue fuel pump with separate regulator and inline fuel filter stainless braided Teflon hose. Sorry it took me awhile to get back to youBeautiful job! What are you running for a fuel pump / system?
