Dizzydean
Thanks a very very lot Racyroy1, me and my son finally got the manifold you gave me on. What a pain and a lot of work for 1 broken stud. So now the new motor is almost complete the parts are slowly getting here. I need 1 end bolt and the retainer for the rocker shaft if any are available. On the new blood the oil pasages are massaged,.030 pistons,block decked .080, piston/rod work done prior to my purchase, double tooth timing set,Earson .465 lift cam,I have polished the spark plug tubes-push rods-and rocker shaft, the head is patiently waiting its turn. Pics at a later time.
