Mopower71
Speed Demon
Good to finally meet you.
Thanks for hooking me up with the springs.
Having some fun getting the bushings out, then I'll get the aluminum ones in and everthing set before I pull the others out.
I had a new set of rear rubber bushings from when I did the relocate on my Charger. But I only found 3 of the 4. I know it;s floating around the bottom of the tool box somewhere.
