If I lay around any longer I’ll get lazy. Well I enjoyed my time off but 1.5 days is enough. The valves didn’t get here for the heads I was working on so I grabbed a Victor340 to do for a Keystone Raceway Park racer.
How do you decide where to scribe the lines? With the intake manifold gasket? Since there's slop in the bolt holes, how do you decide "where" is correct?If I lay around any longer I’ll get lazy. Well I enjoyed my time off but 1.5 days is enough. The valves didn’t get here for the heads I was working on so I grabbed a Victor340 to do for a Keystone Raceway Park racer.
How do you know the ports will all line up when on the block, of things were milled they can move around, right?
Can I ask how you keep your carbide bits clean? I just started working on a Victor340 intake I bought.
Thanks for that. You don't have to share all your secrets but I appreciate it.I use the Edelbrock gasket that I always post up and wheel studs. I force them to catch a thread into the intake. There is zero slop in either the gasket or intake.
Tight lipped. I knew a girl like that a LONG time ago.As you have probably noticed by now I don’t keep a lot of secrets. I do have a few things I’m tight lipped about
Thank you! Follow up question, how often do you have to dip them in ATF? Every couple minutes or once every 15?
I dip them in transmission fluid. I used to mix in WD40 but the price jumped up bigtime on the gallon container. I have a bunch of Harbor Freight money I my look into buying another gallon. I get zero buildup with transmission fluid but the WD40 helps cool them better when I mix some in.
