the day to day grind
TheWhyDesign
Member
So, I dropped the steering column to get the instrument cluster out of my 69 Valiant. After I re-installed the cluster, and bolted the steering column back up, I seem to have aquired a grinding noise when I turn the wheel in either direction. I dropper again and tried to tighten each bold evenly... the grind is still there. Is there something I'm missing here? Any thoughts?
manual steering is not actually impacted.
As always... much appreciated.
Whereas I can't help you with the grinding, got any pics of the car?
I'm working on one too....
You didn't slide the column further in when you re-installed it. did you? Just a thought...might have somebody turn the wheel for you, with the front end clear of the ground, while you look for interference.
keep us informed.
Alan627b
