The Dreaded Tranny Pan Leak
Transmission and Drivetrain Tech
  1. 512Stroker
    512Stroker We are all here because we are not all there.
    2,336
    1706
    May 30, 2016
    Freedom, MO
    Local Time:
    3:54 AM
    SBM 727, Hughes 3000 stall, steel stamped plus 2 quart pan.
    This will be the thrid pan gasket I have tried, I cant keep it from seeping between the pan and the gasket. First gasket was cork, second gasket is stiff rubber like with ridges in it, still leaks. All gaskets were installed clean and dry, no sealant used.
    What trick am I missing here? Sealant?
  2. plumkrazee70
    plumkrazee70 Well-Known Member
    2,901
    862
    May 5, 2013
    Medford, Oregon
    Local Time:
    3:54 AM
    I was wondering this also. I know the modern tranny pans uses mopar atf rtv.
    • Like Like x 1
    • Yunick13
      Yunick13 Well-Known Member
      2,320
      5601
      Sep 7, 2019
      No longer here.
      Local Time:
      3:54 AM
      Have you checked to make sure the flange on the pan is flat?
      • Agree Agree x 3
      • dartfreak75
        dartfreak75 Restore it, Dont part it! FABO Gold Member
        9,973
        7603
        Aug 10, 2011
        Virginia
        Local Time:
        4:54 AM
        I just rebuilt a 999(904) and used a good gasket that came from b&m and its leaking almost instantly i was hoping once it heated up it would seal but so far no luck still leaking like a seave.
      • brian6pac
        brian6pac Well-Known Member
        5,230
        3651
        Nov 15, 2016
        N.E.Ohio
        Local Time:
        4:54 AM
        Spray copper on the pan side, nothing on the trans side.
        • Like Like x 1
        • bcschief
          bcschief Well-Known Member
          874
          456
          Feb 23, 2010
          Crescent City Florida
          Local Time:
          4:54 AM
          Maybe it's the shift shaft seals. Is it leaking on the drivers side at about the middle point of the pan or possibly fluid is running to the back corner of the pan ?
          • Agree Agree x 3
          • Like Like x 1
          • 512Stroker
            2,336
            1706
            May 30, 2016
            Freedom, MO
            Local Time:
            3:54 AM
            Pan was new when I installed it and it is flat.
            Do you know what the torque is on the pan bolts?
          • 512Stroker
            2,336
            1706
            May 30, 2016
            Freedom, MO
            Local Time:
            3:54 AM
            I have already checked for leaks above the pan several times. It appears to be the dam gasket.
          • George Jets
            George Jets 1967 Dart 2 Door FABO Gold Member
            4,533
            6198
            Jan 18, 2019
            Farmington MN
            Local Time:
            3:54 AM
            Here is same what I do for valve covers as well as the tranny pans.
            Clean pan surface and tranny surface, bolt thread holes and bolts and threads with Brake Parts Cleaner to remove any trace of oil or oily solvents.
            Then apply thin layer if black RTV Gasket Maker to both tranny and pan gasket surfaces and a thin layer to both sides of new cork pan gasket.
            Then coat bolt theads with Aviation Sealer (like Hi Tack) to seal threads to the case.
            Assemble the pan onto the tranny with light but snug torque to the pan bolts, tightening them evenly as you go around 3 times.
            Let sit overnight to let RTV cure. Put in your tranny fluid, check when warned up and leave a pint low on the 727s so that you are not overfilling it.
            Check when idling in neutral. Leaving the tranny 1 pint low leaves room for torque converter drain back so the fluid level does not go above the shift shaft seals and forces the fluid out.
            Can seal the nut and band adjustment bolt threads with Aviation Sealer too as fluid will seep from there also if unsealed.
            Never leaks as long as your shift shaft seals are good. Same for 904s too.
            If your front seal at the torque converter is leaking, well that is another story . . .
            • Like Like x 4
            • jdsduster
              jdsduster Well-Known Member
              1,199
              191
              Aug 5, 2011
              indiana
              Local Time:
              4:54 AM
              no better gasket than the crush proof.last gasket you will ever put on.period.put it on dry.
              • Agree Agree x 2
              • Thanks! Thanks! x 1
              • Dana67Dart
                Dana67Dart Like a fine wine, only getting better with age! FABO Gold Member
                6,348
                4164
                Jul 16, 2017
                Northern Colorado
                Local Time:
                2:54 AM
                • rustycowll69
                  rustycowll69 Well-Known Member
                  2,455
                  1197
                  Feb 19, 2016
                  Pacific northwest
                  Local Time:
                  1:54 AM
                  I DO NOT recommend silicone RTV. They make a MOPAR reusable gasket. It came with a factory deep pan on my 02 ram2500. Damn near fool proof!
                  • Agree Agree x 5
                  • Like Like x 1
                  • RustyRatRod
                    RustyRatRod I was born on a Monday. Not last Monday. FABO Gold Member
                    71,784
                    46970
                    Jun 7, 2010
                    Georgia
                    Local Time:
                    4:54 AM
                    Sealant doesn't go on transmission pans. Ever, ever, ever. Period. Make absolutely 100% SURE the pan rail is straight and the bolt holes are not distorted. Don't say "It's a new pan" just frikkin DO IT. How hard is that? Seriously? Next get the best gasket money can buy. That would be this. Rubber with a steel core. Put it on CLEAN CLEAN CLEAN and DRY.
                    Moroso 93110 Moroso Transmission Pan Gaskets | Summit Racing
                    Lastly torque to spec and DON'T over torque. Finally, come back after a few heat cycles and re-torque WHEN COLD. If it's the pan gasket that's leaking, that should solve it. But beware, like others have said, transmission leaks can be tricky. Sometimes a pan gasket leak ends up being a dipstick tube leak, of shaft seals, or something else, so inspect it very closely.
                    • Like Like x 2
                    • Agree Agree x 2
                    • Disagree Disagree x 1
                    • rustycowll69
                      2,455
                      1197
                      Feb 19, 2016
                      Pacific northwest
                      Local Time:
                      1:54 AM
                      The part number is stamped right in the pan!
                      If you are trying to seal a chrome pan, good luck!
                      • Agree Agree x 2
                      • JoePole1
                        JoePole1 A dude in a B body FABO Gold Member
                        646
                        527
                        Mar 3, 2018
                        Hudson Valley, NY. NOT NYC!!
                        Local Time:
                        4:54 AM
                        • Like Like x 2
                        • Agree Agree x 2
                        • 12many
                          12many Well-Known Member
                          1,800
                          2187
                          Dec 14, 2016
                          South Carolina, Thank God
                          Local Time:
                          3:54 AM
                          Don’t forget to check the low/reverse band lever pin/shaft bore on the back of the case for a possible leak. I’ve had leaks there, bad (O-ring) cleaned with degreaser and packed some ultra rtv in there to solve that after thinking maybe the shift shaft and gasket was the source only to have been that shaft and bore.
                          • Like Like x 1
                          • Agree Agree x 1
                          • fishmens67
                            fishmens67 Well-Known Member
                            9,912
                            8443
                            Nov 10, 2012
                            idaho
                            Local Time:
                            3:54 AM
                            I went through 2 different new pans and several gaskets with sealant only to find the dipstick was seeping.
                            It was hard to see, but it wicked around the pan making it look like the pan gasket was leaking.
                            put a new O-ring on and it was fixed.
                          • 512Stroker
                            2,336
                            1706
                            May 30, 2016
                            Freedom, MO
                            Local Time:
                            3:54 AM
                            Listen Boozo (nice Picture) I did not think a step by step explanation was necessary so he ya go.
                            When I said that "its Flat" I should have said that after the first gasket I set the pan gasket surface down on a piece of polished marble and could not pass a .004 feller gauge between the pan and the stone. I figured that that straight for a stamped pan. I do not believe that I have over torqued the bolts as I have secured many pans that have not leaked, but rest assured that when I have the pan off I will check the bolt holes.
                            Thanks
                            • 512Stroker
                              2,336
                              1706
                              May 30, 2016
                              Freedom, MO
                              Local Time:
                              3:54 AM
                              Pan is not chromed
                              • Like Like x 1
                              • fishmens67
                                9,912
                                8443
                                Nov 10, 2012
                                idaho
                                Local Time:
                                3:54 AM
                                It can also wick through several of the pan bolts.
                                • Agree Agree x 1
                                • j par
                                  j par Well-hung Member
                                  27,764
                                  15187
                                  Jul 2, 2014
                                  Portland Oregon
                                  Local Time:
                                  1:54 AM
                                  I wish somebody told me I wasn't supposed to use rtv!...
                                  I foolishly put a bunch of "the right stuff" on both sides of the cheap Court gasket that came with the rebuild kit and never had a leak...
                                  I'm not recommending that only because I don't want Rusty fat mod yelling at me...
                                  • Like Like x 3
                                  • fishmens67
                                    9,912
                                    8443
                                    Nov 10, 2012
                                    idaho
                                    Local Time:
                                    3:54 AM
                                    I tried the right stuff, only to find the tube was seeping.
                                    That stuff was hard to get off, so I didn't use it on the next new pan install. lol
                                    Even had the good Moroso gasket on there one time. Damn leaky dip stick tube. lol
                                    • Like Like x 2
                                    • brian6pac
                                      5,230
                                      3651
                                      Nov 15, 2016
                                      N.E.Ohio
                                      Local Time:
                                      4:54 AM
                                      I pulled a piece of RTV out of a valve body once that wouldn't shift,
                                      Go figure.
                                      • Like Like x 4
                                      • Agree Agree x 1
                                      • rustycowll69
                                        2,455
                                        1197
                                        Feb 19, 2016
                                        Pacific northwest
                                        Local Time:
                                        1:54 AM
                                        I've been watching these trans/transfer case breakdowns on youtube and it's amazing how many units' pickups are plugged up with fugitive silicone boogers.
                                        That being said, my Intrepid auto trans came with silicone from the factory, but the factory has a robot which deposits the PERFECT size bead of silicone for the factory assembly. It never leaked from the pan, BUT it was a real bitch to bust that pan loose without bending the pan, and another bitch to clean all that old silicone off.
                                        If there is a reusable pan gasket, I highly recommend it. IMO, it's worth the extra money.
                                        • Like Like x 1
                                        • Agree Agree x 1
                                        • George Jets
                                          4,533
                                          6198
                                          Jan 18, 2019
                                          Farmington MN
                                          Local Time:
                                          3:54 AM
                                          Good trick for any sealed RTV surface is to loosen up the bolts then spray Brake Parts Cleaner on it a couple times over a 20 minute period to let it soak in, keeping it wet.
                                          It starts softening up the RTV and it comes apart easy. Makes it easy to clean the surfaces down clean to the metal too. Trick is to keep it wet and it softens right up.
                                          Weather it is valve covers, oil pans, intake manifolds, timing covers, etc. makes life easier for cleaning up the RTV.
                                          • Like Like x 1
