The Dreaded Tranny Pan Leak
Transmission and Drivetrain Tech
  1. 512Stroker
    512Stroker We are all here because we are not all there.
    2,311
    1676
    May 30, 2016
    Freedom, MO
    Local Time:
    8:27 AM
    I have checked the dip stick tube several times, no luck, it is sealed up good. I was hoping that it was the tube o-ring it would have been an easy fix.
    • Like Like x 2
    • Agree Agree x 1
    • fishmens67
      fishmens67 Well-Known Member
      9,886
      8398
      Nov 10, 2012
      idaho
      Local Time:
      8:27 AM
      It sounds like you know what you are doing. Good Luck.
      I know what you are going through.
      Don't throw money at it like I did, I spent hundreds until I found the 25 cent O-ring fix.
      Chime in when you find the cause, I'm curious. Thanks
      • Like Like x 2
      • Thanks! Thanks! x 1
      • CudaFactHackJob
        CudaFactHackJob FABO Gold Member FABO Gold Member
        1,651
        623
        Mar 17, 2016
        Hemet, Ca.
        Local Time:
        8:27 AM
        Sometimes the pan rails are distorted up to half an inch on some of the pans I take off. They've been beat on, twisted, dropped, rusted, and mangled. They NEVER leak. My pan gaskets cost $3.50 ea. I use absolutely NO SEALER whatsoever. I use ONLY Duraprene gaskets. CORK??? OMG NO! Rubber? no. Some kind of cork neoprene mix? NO. FLAT pan rail? NO. The holes have to be massaged until they're about 1/16" low. That way the bolt will apply pressure between the bolts as they're tightened down. Then the last turn or so crushes the rail around the bolt. I crank them down ALMOST hard enough to strip the holes. A Duraprene gasket will NEVER split. EVERY pan has to be hammered on before it's re-installed. If I remove the pan after a few months, it has to be pried slightly to separate it from the case.
      • halifaxhops
        halifaxhops It's going to get stupid around here! FABO Gold Member
        65,708
        35259
        Jan 20, 2014
        Hoppyworld
        Local Time:
        9:27 AM
        Here is one that drove me nuts. The trans had a 1/4" bolt hole for mounting the dipstick to. Worth a fast look.
      • limegreen70
        limegreen70 Pokorny Enterprise's
        1,534
        283
        Apr 27, 2014
        Milton PA
        Local Time:
        8:27 AM
        Seems like everyone has a different opinion. I am going through the same thing right now. Ugh it's a nightmare
      • toolmanmike
        toolmanmike FABO MODERATOR Staff Member FABO Gold Member
        58,606
        45935
        Jan 18, 2006
        Iowa
        Local Time:
        8:27 AM
        Just curious, does it leak only when it sits?
      • 512Stroker
        2,311
        1676
        May 30, 2016
        Freedom, MO
        Local Time:
        8:27 AM
        Leaks just sitting and going down the road.
        The exhaust system down stream of the trans is stained from trans fluid.
        • Thanks! Thanks! x 2
        • toolmanmike
          58,606
          45935
          Jan 18, 2006
          Iowa
          Local Time:
          8:27 AM
          Deep pan. You running a filter extension?
        • 512Stroker
          2,311
          1676
          May 30, 2016
          Freedom, MO
          Local Time:
          8:27 AM
          Yes, deep plus 2 quart stamped pan with filter extension
          • Like Like x 1
          • toolmanmike
            58,606
            45935
            Jan 18, 2006
            Iowa
            Local Time:
            8:27 AM
            The extension puts the filter down in the fluid. I would try it a quart low and see what it does. A quart low is still 1 quart over stock capacity with the deep pan. You can always add that quart back at any time. It isn't fixing the root cause of the leak but it might help upi diagnose the leak. Just spit balling here. The fluid level with a stock pan and filter is just at or below the gasket surface.
            • Like Like x 1
            • Agree Agree x 1
            • supertruck
              supertruck Retired Old Fart stock car racer FABO Gold Member
              723
              373
              Feb 14, 2016
              Gloucester, Va
              Local Time:
              9:27 AM
              Had the same issue with the 200-4R on my Sport. Changed to the LubeLocker gasket and no problems since.
              • Agree Agree x 1
              • George Jets
                George Jets 1967 Dart 2 Door FABO Gold Member
                4,469
                6075
                Jan 18, 2019
                Farmington MN
                Local Time:
                8:27 AM
                These Transgo shift kits solve lots of problems, like torque converter Drain Back, allows the pump to pump in Park instead of just Neutral, helping to eliminate the mopar morning sickness on start ups.
                Read the description, many improvements for the 727s and 904s. Changes the shift plunger and internally reroutes the inner flow circuits to Pump in Park and help eliminate Torque Converter Drain Back . . over filling the trans pan and causing other leaks.
                I was happy with them when I have used them.
                Transgo TFSC Shift Kit A727 A904 Torqueflite Transmission 727 904 Chrylser Dodge | eBay
                eBay item number:
                202662324309
                • Like Like x 1
                • George Jets
                  4,469
                  6075
                  Jan 18, 2019
                  Farmington MN
                  Local Time:
                  8:27 AM
                  Here is the write up on the Transgo shift kit cures: ^^^^^
                  NEW Transgo SK TFSC shift kit for all Torqueflite three speed transmissions from 1960-UP
                  This kit corrects the common problems with these transmissions; Premature converter failure and lockup shudder, burps oil out of the vent, front bushing and seal burnup, engages slow after sitting, leaks oil when parked, loss of power when hot, burnup on hot trips, reduces hub breakage, engine bog on start off from stop, reduces harsh reverse, soft, mushy 1-2 shift, extended 2-3 shift. Along with the increased performance from your vehicle, you'll also see an increase in the life of your transmission due to the reduced slippage. This is the most complete shift kit available and definitely the most reputable.
                • RustyRatRod
                  RustyRatRod I was born on a Monday. Not last Monday. FABO Gold Member
                  71,464
                  46593
                  Jun 7, 2010
                  Georgia
                  Local Time:
                  9:27 AM
                  Golly jeepers Beav, I was just trying to stress how important all this was to not bypass. Bozo knows when he's not appreciated. He'll STUFU next time.
                  • Agree Agree x 1
                  • George Jets
                    4,469
                    6075
                    Jan 18, 2019
                    Farmington MN
                    Local Time:
                    8:27 AM
                    It's all good, everyone has their experiences to share. Adds to the total knowledge base. End user can decide what works for them.
                    • Like Like x 1
                    • 512Stroker
                      2,311
                      1676
                      May 30, 2016
                      Freedom, MO
                      Local Time:
                      8:27 AM
                      No disrespect intended toward you, your message came on a little strong.
                      The straightness of the pan was the first thing I went after.
                      After doing this for over 4 decades I'm getting a little cynical.
                      You are welcome to post on my threads anytime and please do.
                    • RustyRatRod
                      71,464
                      46593
                      Jun 7, 2010
                      Georgia
                      Local Time:
                      9:27 AM
                      I meant for it to come across strong. It's that important to get everything perfect. It wasn't meant on a personal level at all. Now when I start out something like "Hay dumbass........" then you can bet it's personal. First off, I would never do that to you, as we've always gotten along. Secondly, that wouldn't be conducive to getting someone to understand the gravity of doing something a certain way.
                    • 512Stroker
                      2,311
                      1676
                      May 30, 2016
                      Freedom, MO
                      Local Time:
                      8:27 AM
                      67 factory service manual staes 150 in/lb's for pan bolt torque.
                      Question
                      Does anyone know what the 1/8 NPT plug is for that is right next to the dipstick tube in the trans case? Pressure port?
                    • 512Stroker
                      2,311
                      1676
                      May 30, 2016
                      Freedom, MO
                      Local Time:
                      8:27 AM
                      Well I did it
                      Cleaned pan very well with K&N filter cleaner and hot water, than a final wipe down of the pan and trans pan rail with brake clean.
                      Checked pan again for staightness/flat all OK
                      Checked bolt holes for distortion, none found
                      I used the gasket that came with the WIX filter kit, some kind of synthetic, pressed it flat over night with a piece of plywood and alot of weight on top.
                      Sprayed the pan side of the gasket with Permatex copper spray and applied the gasket to the tranny pan.
                      Installed the pan and torqued the pan bolts to 150 in/lb's let it set up for 2 days.
                      Filled trans with Valvoline Dex/Merc ATF drove it for 20 miles parked it over night put it up on the rack, no leakage found at the pan.
                      Job over, I hope.
                      Edit-Thanks to all who replied
                      • Like Like x 3
                      • CudaFactHackJob
                        1,651
                        623
                        Mar 17, 2016
                        Hemet, Ca.
                        Local Time:
                        8:27 AM
                        No sealer, Duraprene gasket at $3.50, and not a flat pan rail. Pooch up the bolt holes so they preload the area between the holes. Been doing it for years; works every time.
                      • RustyRatRod
                        71,464
                        46593
                        Jun 7, 2010
                        Georgia
                        Local Time:
                        9:27 AM
                        Don't you mean pooch the holes DOWN in relation to the transmission? That would preload the spaces between the holes that need to seal...
                        • Agree Agree x 1
                        • Don Selleck
                          Don Selleck Active Member
                          29
                          32
                          Aug 5, 2019
                          michigan
                          Local Time:
                          9:27 AM
                          after many attempts i finally got mine to stop leaking, took it off put it on the shelf and put the stock one back on. hasn't leaked a drop since.
                        • CudaFactHackJob
                          1,651
                          623
                          Mar 17, 2016
                          Hemet, Ca.
                          Local Time:
                          8:27 AM
                          ..I only work on transmissions that are up-side-down...
                        • Dartswinger70
                          Dartswinger70 Well-Known Member
                          1,842
                          793
                          Sep 20, 2005
                          Southeastern Pa.
                          Local Time:
                          9:27 AM
                          Not 100 % sure of the pan bolt torque but it is important. I worked in a trans shop and the boss was a stickler about torqueing pan bolts evenly. I seem to remember some of them were in "Inch pounds" also.
                        • 512Stroker
                          2,311
                          1676
                          May 30, 2016
                          Freedom, MO
                          Local Time:
                          8:27 AM
                          With great sadness I am compelled to report that the dam thing is leaking again.
                          I have one more trick up my sleeve to make it stop.
                          Stay tuned for further developments.
