Yeah just like stroked340 motor that lost a rod bolt in those cheap rods, my friends 440 that buzzed a cam in half/broken rod bolt (toasting the block), or another SB that detonated a crank into three pieces.
They had one thing in common, none ran nitrous!
Like I've said before, you build your best baddest engine go run it, then I'll juice it and beat you with your own stuff. Just how you want to get down the track or run the streets. Reality is, virtually anything a person can build NA, you can make run faster with nitrous.
That Duster is total bada$$!
