Think I might need longer pushrods..
Rockerdude
Rock n' Roll and A-bodies
Arizona
Hey guys, I just finished my 5.2 magnum in my wagon and it has a lot of valve train noise at any rpm. The cam I used was a reground stock one and I just reused the stock pushrods, so I'm betting that is the issue. I've talked to the cam grinders and they sugested a .050 longer pushrod. Could anyone lead me the right way to getting what I need?
You won't know............until.............you actually measure the clearance. Otherwise, you are just guessing.
A common problem,with re-ground Magnum rollers.I bought a new roller blank core, when I did mine.They take more off the base circle,on a regrind.Might P.M LXguy,he has been through this,I.I.R.C.
