Hello,
I'm thinking of selling my Duster as it just sits in the garage and never gets used. It's a 1971 Plymouth duster with a 360 engine originally a 318 car. Specs of the car are below. Just trying to get an idea of what it is worth in today's market.
Engine:
Built by Hughes engines, it's a .060 overbore 1972 block
rotating assembly was balanced
BHJ harmonic balancer
Eagle I beam rods
Diamond forged pistons set up for a compression ratio of 10.5:1
Edelbrock Rpm aluminum cylinder heads with Hughes engines stage 2 port job
Hughes engines Hydraulic flat tappet cam specs with the 1.6 rocker arms
are .571 Int. and .576 Exh
Double roller timing chain with tensioner
High volume oil and water pumps
Hughes engines roller rockers 1.6 ratio
Edelbrock Rpm airgap intake, also ported by hughes
Edelbrock 750cfm carb with K&N air filter
Trans:
Rebuilt 727 trans
A&A transmission torque converter with 3800 stall
Plate type trans cooler
B&M shifter
Various info:
Has a Be cool radiator in it with a spal fan, also has a flex o lite pusher fan mounted on ac condenser
Optima battery
Distributor and coil are FBO components
Has the large bolt pattern on the front with disc brakes
big block torsion bars
magnumforce upper tubular control arms
As you can see in the pic's it has Weld racing pro stars on it. Rears will need to be changed because it has wheel spacers on it for the 5 on 4 bolt pattern.
Hooker headers
Jegs mandrel bent exhaust system
8 3/4 diff with awesome 2.76 gears in it, I beleive it is a 741 case
Vintage air Gen 2 system
Full autometer gauges
Painless wiring fuse block and associated wiring
As you can see this is a work in progress that I bought a couple of years ago. The body is decent but no where near perfect and has some scratches and some bondo bubbles coming up through the paint. The floor pans are decent but have some holes in both the front pans, but it is very far from Fred Flintstone, largest hole about the size of a quarter.
The wheel adapters is something else that I haven't got around to yet, but I have a Ford 8.8 rear that will go with the car if you want it. I was going to so that conversion as well as upgrade to rear disc brakes. I also want to ditch the front seats as they weren't my style. But funds have been low and they are not torn or broken so they have stayed. That is really why I am selling it, as I don't have the money to fix it the way that I want to build it.
I'll let the pics do the rest of talking, but if there is any other info that you think I need to post up please let me know.
Engine:
Eagle I beam rods
Trans:
Rebuilt 727 trans
B&M shifter
Various info:
Optima battery
Hooker headers
