YWGScamp72
Active Member
Hello looking for input on my 318 build
1972 Plymouth scamp hardtop
Currently stock bore 2bbl 1972 318
Rebuild 30kms ago
Compression 160 psi across all cylinders
904 trans
2200 stall
fully built
Stage 2 shift kit
Posi 8 1/4
3.55 gears
2.5 dual exhaust with thrush v force mufflers
Power steering
Man brakes
No a/c
On order are
Speedmaster 65cc 170cc hyd flat tappet heads with stud kit (black Friday sale 40% off!!!!)
Comp xe268h 10 cam and lifter kit
Double roller timing chain
Mr gasket thin head gasket (.023mil compressed I think)
full gasket set
Billet distributor and 8mil wires
New cha.pion plugs that for new heads
Edelbrock 600cfm 1406
Edelbrock performer intake
Hooker long tube headers
arp torque lube and permatex assembly lube
Planning to reuse stock Rockers, shafts, and pushrods if they are the right length
Let me know if I missed anything or you opinions/ criticism on this build.
Rebuild 30kms ago
904 trans
2200 stall
fully built
Stage 2 shift kit
Posi 8 1/4
3.55 gears
Power steering
Man brakes
No a/c
On order are
full gasket set
