Not posting this as a rebuttal to videos above just the other side of the coin., generally the average dude with a credit card only has less than a handful choices of cylinder heads and not running the optimal cam, cr, gear etc.. the above method is gonna have less bearing on what he's gonna do. Richard shows even though the larger heads aren't a power/torque killer on the dyno but the throttle response/driverability could be a different story.
Only the first 15-20 minutes he goes on about his thoughts on CAS which basically he doesn't worry about it. He focus on the low hanging fruit hp gains, which like most aren't gonna put together a highly dialed in engine. Obviously in a highly competitive race class the above method or similar is the only way, but on a vague engine goal like burn out machine probably not so much.
