Thoughts on what ive compiled for a build? Any changes or suggestions?
1970boy
California
ENGINE
magnum 5.9
HEADS
-magnum engine quest heads best flow
-tight quench .30 bowls opened up
-weisco dished pistons
INTAKES -MAGNUM HEADS DRILLED FOR LA INTAKES
-mopar m1 performance dual plane intake
OR
2176 edelbrock dual plane intake
CAMSHAFT
-Roller cam Compcams #20-000-9 506 lift 216 intake 224 exhaust duration.
OR
-Oregon Cam Grinders regrind214/224 and .512 lift, 110 LSA with thestock hydraulic roller lifters
CARBURATORS?
-Thermoquad 850
OR
-Edelbrock 1406
PROS
-hydrolic roller cam
-generally more efficient than la360
-option for oem efi
TRANSMISSIONS
-Perfect fit 6 speed
OR
-Perfect fit 4 auto
OR
-727/904 with gear vendor unit
EXHAUST
-Mopar TTI 2.5 inch dual exhaust system?
-best exhaust system option??
CONVERSION
-disc brakes?
-driveshaft length?
-schumaker creative services conversion mounts for /6 to 360
MISCELLANEOUS
-Aluminum radiator
-compression ratio?
-electric fan
-msd ignition
-msd distributer
-Tall tire 24-26 in
-Best gear ratio option??
-1-5/8 inch headers????Best size in your opinion
