N Nu2Mopar Well-Known Member Joined Mar 21, 2009 Messages 244 Reaction score 3 Location NorCal Feb 26, 2012 #1 Quick ??, what is the thread size on the fuel pump for the feed line to the carb on a 360? trying to buy a fitting for it... Thanks! Steve
Abodybomber Breaking street machines , since 1983.....:) Legendary Member Joined May 21, 2011 Messages 30,853 Reaction score 7,188 Location Arroyo grande ca Feb 26, 2012 #2 depends on the pump,stockie?Or Carter hi flow?
N Nu2Mopar Well-Known Member Joined Mar 21, 2009 Messages 244 Reaction score 3 Location NorCal Feb 26, 2012 #3 Abodybomber said: depends on the pump,stockie?Or Carter hi flow? Click to expand... Stock...
Abodybomber Breaking street machines , since 1983.....:) Legendary Member Joined May 21, 2011 Messages 30,853 Reaction score 7,188 Location Arroyo grande ca Feb 26, 2012 #4 5/16 or 3/8 inverted flare.Buy both,return the one you don't use.Most likely 5/16 inverted,if looked up for a 318,or 360 smogger.
67Dart273 Well-Known Member Joined Oct 14, 2010 Messages 60,802 Reaction score 34,420 Location Idaho Feb 26, 2012 #5 Some pumps are pipe thread and need an adapter................. Can you see an inverted flare seat in the bottom, or just a "black hole?"
N Nu2Mopar Well-Known Member Joined Mar 21, 2009 Messages 244 Reaction score 3 Location NorCal Feb 27, 2012 #6 Yeah, i think it might be pipe thread. it doesn't look tapered at all?
