J jack colv Active Member Joined Dec 10, 2021 Messages 34 Reaction score 8 Location Pa Today at 6:09 AM #1 working on 1973 Plymouth Duster 340 using a avs Carb. off a 1971 340 I have no cable anyone have any idea what for cable I can use Thanks
66fs FABO Gold Member FABO Gold Member Joined Sep 9, 2009 Messages 9,320 Reaction score 4,648 Location Greenwood, South Carolina Today at 6:55 AM #2 You should use a cable for a "73" 340 Duster. If you are running an automatic trans, you will also need to address the kickdown system. 1971 used a TQ carb, so your AVS should be from 1968-1970. What are the numbers on the carb?
