LImopar
Active Member
Just wondering if anyone knows where I can purchase the throttle cable stud that bolts onto the throttle lever and allows the clip on the end of the throttle cable to slide over. I believe it has pre drilled holes in it for a pin to keep the throttle cable from coming off and the other side for the return spring to go into.
