Pumpkinduster
I am looking for someone that is running a small block with an edelbrock carb. I’m trying to figure out the proper way to attach the throttle and the kick down. I purchased the Chrysler adapter as well as the needed studs EDL-8007, carb is a 1405. I just want to make sure I get this all setup right. Also if you have pictures of your spring setup for kick down and throttle return.
