Aaron.M
With a 489 cone style Sure Grip and Green bearings with Moser axles, do I need to remove the thrust block from the Sure Grip or is that just for the 741 and 742 cases? What is the meaning behind it?
I think it may depend upon if you use Mopar Performance or older Green Bearing (RP400) versus the newer style MO400.
I believe that the MO 400 uses snap rings which may give enough room so that you do not have to remove the block or button. The Rp400 the bearing was crimped onto the retainer moving the axle inward so the block or button had to be removed. Call Dr Diff he can verify what needs to be done.
Also look and see which style green bearings you have there are two different ones RP 400 ( crimped onto the bearings ) and MO 400. ( snap ring style ) I am almost positive since I went out and checked my 8 3/4 that you are good to go with the MO 400 style bearings. ( they move the axles out slightly where the RP 400 moved the axles in slightly. )
I have snap rings on one side of the bearing and a slot on the other side for what looks like an o-ring that did not come with the set, I'll have to find a couple of those I suppose
Hi Aron Majcan,With a 489 cone style Sure Grip and Green bearings with Moser axles, do I need to remove the thrust block from the Sure Grip or is that just for the 741 and 742 cases? What is the meaning behind it?
Exactly my experience as well. Just curious. When you ordered your axles, did you give your supplier the specifications of your setup?I got the backing plates and Moser axles in this morning and they slid right up to the snap rings on both sides so it seems that, in this application anyway, the thrust block can remain on a cone style sure grip with the snap ring Green bearings.
I've heard it was only the 741 and 742 cases that need the thrust button removed. From what I understand, the 489 case has a thrust block (not a button) that doesnt have to be removed for Green bearings but I'll maybe try calling Dr. Diff.
You are a tad confused. It's not predicated on the housing, it's the suregrip unit itself.
Clutch type suregrip has the thrust buttons. The buttons are easily removed.
Cone type suregrip has a thrust block. In order to remove the thrust block the suregrip unit itself needs to be disassembled.
IF you have the newer Greens then I think the buttons/block can stay. If they are the older ones it needs to come out.
OR as mentioned if the splines on the axle ends are long enough you can just remove a little bit of the axle end.
