Tie rod threaded length issue.
tcanin00
Harrisburg, PA
After converting my '71 Dart Swinger to disc brake with FMJ knuckles and Proforged solid aluminum tie rod sleeves, it seems like there is a lot of thread showing on the tie rod ends. I know the conversion pushes the wheel mounting surface out about .937 or 15/16th per side. I assumed the width is gained in the rotor/hub/spindle assembly, not in the location of the outer tie rod end. Is the original drag link different from a '73+ disc brake equipped car?
After replacing some parts of the front end, the toe in was about the same in the first two pictures, with a lot more thread showing than I feel comfortable with.
Picture of the car in question.
Edited for clarification.
