Tilt steering column
B.Ringer
ALL MOPAR
maryland
Has anyone put a tilt steering column in a 66 barracuda ? If so what manufacturer ? What did you do about the wiring connection? Is there a connector adaptor ?
Chrysler made tilt columns for cars ( probably the land yachts) they might be more comparable to A bodies
i used a 28 inch from ebay on my 71 dart. fits well. had to use aftermarket mount but mounted it to my stock location. and the did some mods at firewall. it used chevy wiring, so you will have to make a connector. if i get out to garage, i will find mine and post pic.
I will be using a 1980 M Body tilt column in my 65 Dart wagon conversion. I’m also using a combination wiring harness - part M Body and part 65 Dart harness. It was very important to have the wiring diagrams for both to marry the two harnesses. So when I install the column all the plugs on the column - ignition plugs, turn signal plug, etc will plug right into the modified harness
Thanks
Thanks
Thanks
Thanks
