Time? Power?
Mike@HHPC
Member
360 bored .40 over. forged bottem end. not stroked. 10.5.1 flat top pistons, .533 purple shaft cam, good J heads, M1 single plane, holley 750, hedman long tubes, 3500 stall 727, manual valve body. 8-3/4 3.55 gears 28" tires. What should i expect 1/8mile time/speed and power wise?
Alot depends on the race weight, altitude, i think those 3.55s are not going to be near enough for that build, i had a similar set-up in a 73 swinger with a 3000 stall & 4.56s, car was a screamer, but one day just for kicks, i dropped in a 3.55 set i had lying around, man what a difference it made, killed it actually, you need more gear for sure, bare minimum 4.30s.
