Time to show off those 273's and 318's!
gagembassett
Iowa
So obviously 340s and 360s get tons of love but how about a post for some 273 and 318 appreciation?
1965 Dart GT 273
Here's my 318:
+0.060" kb167s, 9.8:1 CR, factory crank and rods set up for floating pins, windage tray, baffled sump, HV oil pump. Cam is a solid flat tappet - 230°@0.050" 0.574" lift on 110LSA, howards EDM lifters, rollmaster dual row timing set. Aeroflow heads (China castings) minor port work & 5 angle valve job, beehive springs, B3 geometry kit, smith bros pushrods & 1.6 ratio PRW rockers. Ported Weiand action plus intake, 650cfm AVS2 & tri-y headers.
Commando 273 in my 65 Barracuda January 1969. Blew it up November 1972 trying to drive 200 miles in second gear after breaking the 3-4 shift lever. My ship was headed to Viet Nam, so had to get it home. Had 150K on it at the time.
318 after a fresh rebuild. About to go back into its home. 71 twister
The one in the corner is the original factory engine to my car (bored 60 over), gone.
The other one is a 66 block that is now in the car.
At this time I had the one in the car and two more. Now just one spare block.
All 273s
Alan
Odd camera angle but it's after I dressed my battery up to look like OEM. THe engine has been in for 12 years now. (I need to straighten out that hold down bolt)
"66" 273 Commando 105 TRW forged pistons, Isky E-4 solid cam, stock AFB and intake, 4 Speed .71 O/D, 64-65 Hurst shifter, 3.91 Power-Loc sure grip, original Formula S suspension.
