Timing Chain Drip Tab PN?
Mean416
Georgia
Hey guys I'm trying to find a replacement drip tab for the timing chain drip oiling. I can't seem to find this anywhere. I did post in the wanted section but not having any real luck there.
If this doesn't exist I'll probably just have some laser cut. Could someone here drop a couple pics up with a tape measure in the background to give me x/y coordinates? Also need a side view so I can see how much and where its bent.
maybe this will help? Copy the drip portion. All I have is this piece.
You don’t need it. Drill a small hole in the cam plate and send it.
None of that junk ever did anything. Like the bolt with the hole in it. Does absolutely nothing.
Drill the hole and get pressurized oiling on the timing set.
You dont even need the drilled bolt, just leave one bolt out.
Shoot me your address in a PM, I will send you a tab.
