Dusterfool
where can I find cam plate bolt that has a hole drilled in it to allow oiling of the timing chain?
Thanks, I'll try that.You make it yourself.
1/64th" hole in the oil galley plug ifyou don'twantto use a bolt.Like 3/32 hole. But I could be off?
So I just use the bolts and the oil tab?If I drilled a hole it would be very small not like the one in picture #8 that's way to big 1/64th like toolmanmike said, but I have never seen the need,
never had a problem in 40 years in running 340's
I just looked in the book. The 1/64" hole in the oil galley plug I'd to provide oil for three fuel pump eccentric. I can't believe it wouldn't provide a little oil for the timing gears and chain. I did this to my 273 with nice side effects. I will try to post a pic in a sec.1/64th" hole in the oil galley plug ifyou don'twantto use a bolt.
I am running an electric fuel pump, do I still need the eccentric?View attachment 1715008624 View attachment 1715008625 From the "How to build Big Inch Mopar small blocks bookView attachment 1715008615 View attachment 1715008616
Nope. If one is installed no issue.I am running an electric fuel pump, do I still need the eccentric?
