Timing chain replacement 360
Black Girl
Active Member
Phila, Pa.
Hey guys. This is what I found under the cam gear. 4 bolts, no dripper. Is this acceptable ? If not where can I get what I need? Thanks guys
Yes. No dropper, no bolt with a hole. If you want more oil to the timing set drill a hole in the cam retainer plate where it covers either oil gallery. .040 is big enough
2 Ace replies, BadaBING BABY!
Well done gentlemen!
Thats a good price on the kit considering how much the intermediate bushings have went up in the past year.
Many engines were just like yours. They stopped putting the drip troth in and eventually the hollow bolt. I always use both....just because. Some will argue none of its needed but it really cant hurt.
