timing cover gasket issue
Slappy
Tampa Fla.
I bought a timing cover gasket for my 360 and the gasket had an extra bolt hole right in the sealing area. I had this issue before and found a tcs 6563-1 felpro set on my shelf missing the gasket only. Im thinking I used this one on my other engine. I looked up the picture on the net and it has the extra hole. Maybe its a generic picture. Anyone know for sure what to use?
The older covers (69 and back) used the extra hole. I've used that gasket with the extra hole with my newer cover (70 and up) and it's not a problem.
same here, sealed up, no leaks,i just trimmed off the portion of the gasket hole that sticks out,no problem.
