You are very welcome.Thank you kind sir.
Is there an ID for the seal?
I believe there is a kit that includes a sleeve for a worn balancer, hence the larger dia seal.That's intersting I have 4 seals 3 which are same (3103) and a 4th which has a slightly larger ID.
I'm pretty certain they all came from Felpro kits.
Thanks again
That would make sense. Thanks!I believe there is a kit that includes a sleeve for a worn balancer, hence the larger dia seal.
