rm69dart
need help on this timimg issue. timing set on 8 before but it jumps hi and low like 3 numbers at idel. its a 340 with ld340 intake, 1406 carb, 360 heads, mild cam, just built motor. where do i start looking. thanks
67Dart273; !!!!!!!!!!!!!!!!!!!!!I would not immediately assume that the distributor is the problem!!!!!!!!!!!!!!!!!!!!!!!!
hey mad dart this bushing from hughes. does the intake manifold have to come out to install.
So because someone wants to bet with your money that you need a new distributor, you are just going to go buy one?
Seems to me we already covered "spending other peoples money on the internet"
OK, fair 'nough. You said you'd "bet 100% that it is the distributor" so I took it you were dismissing all other problems. Of course it COULD be, and even probable as these dist.s are certainly a problem area from time to time.
Sometimes I get "old and cranky" But I never have liked arbitrarily throwing parts at a problem.
First thing before spending any money... up the idle timing, reset the carb and see if your timing scatter issue clears up. I bet it does MUCH better at 14-16 initial than it does at 8! You'll have to fix the mechanical so your total number isn't out of bounds.
Any kind of cam, I'd idle it at a minimum of about 750 in P/N
well moved timing and did carb ajustment, samething timing jumping, also checked for crank to rotor play none and disconnected vacuum. using different timing light today.
