What is everyone running for timing chain sets in he LAs and magnums? Quality is more important than price to me.
I like the Edelbrock timing gear/chain. 65'
Wonder if a Dakota 3.6 timing tensioner would help out. I put one on the engine I put together but haven't run it yet.Mancini billet set
Jp is nice but when you degree it..
Anyone else check tension after a season with one? Mine was loose.
All it helps is keeping the chain from flopping around. If the chain stretches, the timing will still change even with a tensioner on it. I still like the tensioners though, I think they're a good idea AS LONG AS the chain that's used with them does not have the "dog bone" style links. Those type chains will dig into the tensioner shoes and cut grooves on them. The straight style links will not.Wonder if a Dakota 3.6 timing tensioner would help out. I put one on the engine I put together but haven't run it yet.
Should do, I'm setting up a MP tensioner on my 318 as well. I added a fourth bolt hole in the cam retaining plate and drilled some big holes to expose the lifter gallery plugs, then i drilled a 0.025" hole in each gallery plug to oil the chain & fuel pump eccentric.Wonder if a Dakota 3.6 timing tensioner would help out. I put one on the engine I put together but haven't run it yet.
Rollmaster or Comp. Thr R/M is a Iwis chain & the Comp is Rolon.
Good stuff right there !!!Should do, I'm setting up a MP tensioner on my 318 as well. I added a fourth bolt hole in the cam retaining plate and drilled some big holes to expose the lifter gallery plugs, then i drilled a 0.025" hole in each gallery plug to oil the chain & fuel pump eccentric.
The JP & Rollmaster are good timing sets, Rollmaster do them with Nitrited gears as well and can be ordered undersized if you need.
Cloyes sux. If you say so. Work pretty well for me. There's different levels of cloyes. I used the more expensive true roller race set.Pro gear from Hughes. Cloyes suck. Changed out the Cloyes in my 340 that had 20 hours and the thing had a ton of stretch…
