timing
72swingerwoman
Active Member
i have a 72 dodge dart swinger, 318 does anybody know the timing for this, and i do have a comp cam in there not sure if that changes anything, but i have to check the timing and get that squared away, starting way way to hard. thinking the timing has to be off.
thanks..
Factory setting was about 6 BTDC. Try 12 BTDC at 900 rpm and 35 max at all in.
