SRT_DSTRHOLC
What would cause my timing to be jumping around? vac. leak?
When you turn the rotor 1/4 turn,does it have pressure?Does it spring back when released?If not your rotor is foobard!i was messing with the rotor earlier before i set timming. I think i need to tighten them more, does it matter if the rotor moves left to right like 1/4 turn?
sloppy how?
Are you using a MSD or similar control box? If you are, then the timing will jump some depending on which pulse your timing light picks up. The way to check it is to dial your timing light up to your total timing and then check your timing when the engine is revved up to the all in point or just a little above that rpm (maybe 3500 or so). If it is dead on then the timing light is picking up different pulses and all is fine.
Jack
The oil pump/distributor drive shaft runs through and sits on a hat bushing that is pressed into the block. If that bushing is worn it will allow the distributor drive shaft gear too much room to move around and it will destroy the cam and drive gear....and who knows what else!
If your running the MSD box,with old dizzy,maybe it,s time for someone to go over your dist. and set springs or re-build?When you turn the car off and it stays running(kinda)this is called run-on,your timing sounds off.Try setting again,maybe to far advanced?I have fresh motor with the MSD box and pro-billet MSD dist,with springs set.Or just get a new MSD dist.(expensive)But worth the piece of mind.My 2 cents.also when i turned the car off it was still running but wanted to die sort of, so i turned the key back on and then off and then it died. Maybe a big vaccum leak some were
