That is very interesting. I have never seen them come like that. The sets I bought always had both the metal and the blue intake gaskets.
I used the metal gaskets. I milled the heads and the intake also. The blue ones were too thick. I sprayed them with Permatex and used Mopar black silicone for the end seals. No problems. tmm
That the problem I am having. The blue ones are too thick.
"They" say to never use the metal ones with aluminum intakes, but after running across the same problem you are having I did it anyway and just used a thin coat of sealer on both sides.
Been about two years now without issue, but do yourself a favor and use sealer on your bolt threads or you'll end up with puddles of oil around the bolts.![]()
Just got the fel pro intake gasket set yesterday. The kit is for the 273 engine. In the kit is 2 metal intake gaskets, 2 cork gaskets and a small tube of black silicone. No blue gaskets. I have stock heads and edlbrock intake. Is this the good gaskets?
A lot of times when a set of heads is machined, only the block surface is touched. This can cause the intake bolt holes to not line up properly. Material needs to be removed from the intake sealing surface of the head as well.
I just test fit my new air gap intake on my 360. I can just barely get the bolts started. The bolts cut threads into the bottom of the intake holes. The heads need to have a little material removed from the intake surface so the intake will sit a little lower.
