Tips for HP gain?
Small Block Mopar Engine
  1. Hansen
    Hansen Well-Known Member
    76
    18
    Jan 27, 2020
    Norway
    Local Time:
    1:41 PM
    Hi guys, i wanna get the most HP out of my engine, what do you think will help the most?
    I have not had it on the dyno but it does 9.5 on 1/8 mile with 75 mph over the line. (with bad traction).
    Engine: 1974 360 .30 over
    heads: ported 596 J-heads 1.60/1.88 valves
    Compression: 9.5:1
    Cam: Xe274-H flat tappet
    Duration @ 0.006": 274° / 286° Duration @ 0.050": 230° / 236°
    Max Lift w/ 1.5RR: .487" / .490" Lobe Separation: 110°
    Intake: LD340 edelbrock
    Headers: dougs D453 1-5/8 Inch
    Carb: 670 vaccum secondary holley.
    Cooling: stock waterpump, 1117 flex a lite 6 blade ''race'' fan.
    ignition: Stock electric ignition all around w/orange box.
    Fuel delivery: stock replacment mechanical.
    Timing: 35 at 3500 rpm.
    Unrelated to the engine hp:
    3:23 gears in a 8 3/4 sure grip, 727 manual shift, 3000 stall.
    Car is a 1969 dodge dart GT.
    Let me know if i forgot any info.
    • Like Like x 2
    • 318willrun
      318willrun Utube channel 318willrun
      15,536
      16676
      Sep 13, 2013
      I'm here
      Local Time:
      7:41 AM
      Gears and converter??? What's it in???? What was the MPH in the 1/8 ???
      All the power does nothing if you can't put it to the ground. Fix the traction issue first. Then, are you talking major items like heads??? Or small changes??? For smaller items I'd swap the carb to a 750 double pumper. Make sure your tune/timing is correct.
      • Like Like x 2
      • Agree Agree x 2
      • dano
        dano Evil Handy Man
        3,335
        1206
        Aug 22, 2005
        Gresham, Oregon
        Local Time:
        5:41 AM
        Did you degree the cam?
        • Agree Agree x 1
        • Hansen
          76
          18
          Jan 27, 2020
          Norway
          Local Time:
          1:41 PM
          3:23 gears and 3000 stall, 727 with manual shift, 74 mph in a 1969 dodge dart. really don't need to worry about the stuff around i got a plan on that already. Think like you were building the engine for a dyno test.
        • Hansen
          76
          18
          Jan 27, 2020
          Norway
          Local Time:
          1:41 PM
          Not sure what you mean on degreeing the cam? I have 35 at 3500.
        • Hansen
          76
          18
          Jan 27, 2020
          Norway
          Local Time:
          1:41 PM
          Has been thinking of heads but is there any major gain to justify 1600 bucks?
        • 318willrun
          15,536
          16676
          Sep 13, 2013
          I'm here
          Local Time:
          7:41 AM
          well then, the 1/8 mile time in your first post was irrelevant as well.... LOL
        • 318willrun
          15,536
          16676
          Sep 13, 2013
          I'm here
          Local Time:
          7:41 AM
          I gave 730 for a pair of Speedmaster heads fully loaded on black Friday sale. Don't know how your ported heads would stack up to them, depends on the porting job. Throw on a 750 DP and tune it. TUNE..... Speed is slow in the 1/8 even for bad traction.
          • Agree Agree x 1
          • Hansen
            76
            18
            Jan 27, 2020
            Norway
            Local Time:
            1:41 PM
            i thought instead of a dyno test to give you some idea on how much hp i have to start with. will delete it.
          • 318willrun
            15,536
            16676
            Sep 13, 2013
            I'm here
            Local Time:
            7:41 AM
            no need to delete.... It is relevant, but to help understand the time you ran we needed to know what it's in (for weight) and gears, etc. 5800 lbs Maxi Van or a 2800 lbs early A, big difference. LOL. As I stated earlier, 74 mph is slow for that combo, unless you are doing a 450 ft one tire fire. What I'm saying is you are not getting the potential your combo has currently, so why throw parts at it? Tune it.
            • Agree Agree x 2
            • Like Like x 1
            • Slantsix64
              Slantsix64 Well-Known Member
              2,755
              1090
              May 11, 2014
              SGV
              Local Time:
              7:41 AM
              275 60 nitto street slicks on 8 inch rim, 4.10 gears, trans go shift kit, and a 750 double pumper. Should help you out.
            • abdywgn
              abdywgn dismantler
              1,493
              740
              Jul 30, 2006
              Darien, Illinois
              Local Time:
              7:41 AM
              windage tray? 360 would probably like 2.02" intake valves next time the heads are off. carb spacers if you have room. agree with bigger carb, ran a 750 vacuam secondary carb on a 340/4-speed/3.23 SG with 27" tires...good for 108 in the 1/4 (didn't use 4th gear). I did degree the cam, total timing was 36 at 3500, and the carb ran the black spring so the secondaries never fully opened.
            • dart_68
              dart_68 Well-Known Member
              655
              444
              May 25, 2017
              Lakewood, CO
              Local Time:
              6:41 AM
              I have to respectfully disagree with the double pumper. Gears aren't nearly steep enough coupled to a 727. The CFM is ok but I think a vacuum secondary would be much better.
              • Agree Agree x 2
              • dano
                dano Evil Handy Man
                3,335
                1206
                Aug 22, 2005
                Gresham, Oregon
                Local Time:
                5:41 AM
                That's your total timing and curve, which is important to know.
                A good read on the subject and I'm not being a snob about it as I used to not do it either until I saw the light.
                What is Meant by Degreeing the Camshaft, and Why is it Necessary?
              • 33IMP
                33IMP Well-Known Member
                353
                347
                Jul 3, 2020
                Taxifornia, soon 2b arizona
                Local Time:
                5:41 AM
                Best investment to go faster at the strip? An extra set of cheap wheels and a pair of decent used slicks.
                If you have traction problems now, what is the point of more power?
                • Agree Agree x 2
                • Like Like x 1
                • RammerJammer75
                  RammerJammer75 Well-Known Member
                  538
                  679
                  Aug 28, 2020
                  Kingsport, TN
                  Local Time:
                  8:41 AM
                  He's talking about putting a degree wheel on and verifying the cam advance/retard.
                  • Agree Agree x 1
                  • 318willrun
                    15,536
                    16676
                    Sep 13, 2013
                    I'm here
                    Local Time:
                    7:41 AM
                    That's cool, but when my 360 was stock with stock exhaust manifolds, stock converter, and 2.45 gears it ran the best 1/4 mile time and best 60 ft time with the 750 dp. Other carbs that had a chance were a 600 eddy and 770 vacuum secondary. Proper tuning is key.
                    • Agree Agree x 4
                    • Like Like x 2
                    • Hansen
                      76
                      18
                      Jan 27, 2020
                      Norway
                      Local Time:
                      1:41 PM
                      why not? I rarely go to the strip, but when i do i don't won't the power saving to kill me.
                      As i mentioned before i have a plan on the traction problem (will be getting slicks and move in the leafs), only thing i want to know is if i want more power, what i should aim at?
                      thanks.
                    • MiradaMegaCab
                      MiradaMegaCab Well-Known Member
                      1,137
                      727
                      Feb 5, 2011
                      Long Island NY
                      Local Time:
                      7:41 AM
                      N2O
                      • Thanks! Thanks! x 1
                      • Agree Agree x 1
                      • Hansen
                        76
                        18
                        Jan 27, 2020
                        Norway
                        Local Time:
                        1:41 PM
                        I have choosen my carb based on this video, and calculated the cfm by his number.
                      • 273
                        273 Well-Known Member
                        3,395
                        1128
                        May 14, 2012
                        Ontario
                        Local Time:
                        8:41 AM
                        Heads are where the power is at everything else you do is to make most of what the heads have available.
                        Take your combo and swap different heads on and you'll come up with vastly different power levels and bands. Eg.. 318 heads vs 1.88 360 heads vs Edelbrocks vs trick flow each one is total change the powerband and power level.
                        You could go with bigger cam but your probable already getting 90+% of the power out of those J heads.
                      • Hansen
                        76
                        18
                        Jan 27, 2020
                        Norway
                        Local Time:
                        1:41 PM
                        thanks, thats what i'm worried about is if spending 1600 bucks on edelbrock heads and only get 30 some hp more. really don't want to change out the cam bc of the power brakes.
                      • 273
                        3,395
                        1128
                        May 14, 2012
                        Ontario
                        Local Time:
                        8:41 AM
                        Depends how well your heads are ported, if they flow as much as the Edelbrocks probably not much of a power difference then. Once you get past the basic cam, headers 4bbl each NA hp gets harder and more expensive to obtain. Trick Flows will definitely add power, Nitrous would be the cheapest.
                        I agree with the others get your traction problem fix 1st, more power will make it's worse. Then go from there.
                        • Like Like x 1
                        • Hansen
                          76
                          18
                          Jan 27, 2020
                          Norway
                          Local Time:
                          1:41 PM
                          Ofc the traction is my first priority, just curious on what you guys would recommend. if i change my heads this will probably raise my compression to 10.5, this should make pretty much hp though or is the flowing that matters?
                        • 273
                          3,395
                          1128
                          May 14, 2012
                          Ontario
                          Local Time:
                          8:41 AM
                          Cr matters but you'll gain like 5% so on 400 hp engine thats like 10-20hp so you had air flow gain with it would be good but cr alone not so much for the money.
