Fiberglass and metal do not mix. Adding fiberglass to metal is hack repair 101, and a sure sign of substandard work. Always. There's a right way to do it, and that's not it.Make the back side of the door thicker, add a couple layers of fiberglass mat with resin to stiffen it up.
The whole chassis has been stripped so I am working with with bare metal.
I have two boards clamped on either side in an attempt to bring the memory back to the metal. I will apply some heat with a propane torch evenly accross the skin of the door.
I also considered tacking a metal bar inside the door skin as a reinforcement like the later models have. This is a 69 Swinger 340 car.... My 73 340 Sport had them from the factory... IIRC....
I agree 100% I had a dent on the wifes car, front fender. Same thing and it popped right outFiberglass and metal do not mix. Adding fiberglass to metal is hack repair 101, and a sure sign of substandard work. Always. There's a right way to do it, and that's not it.
Propane torch and a wet rag should work just fine. Heat it with the torch, cool it with the wet rag, should shrink it up pretty well. You don't need the metal red hot either, just hot. And you shouldn't need to heat the whole door skin, just the area of the dent. If done correctly you shouldn't need anything behind it. Easier said than done of course, there's definitely skill to shrinking the metal the right amount.
I offered a solution that will work.
The OP is asking a bodywork 101 question, so heat and a beginner normally end up with more damage.
If a guy didn't have access to an acetylene torch, would a propane torch get it hot enough? I've been doing bodywork for years, and I guess I've been lucky enough to never come across a dent like that.
It's the wrong way to do it.Period.
You'd be better off just slathering it in bondo. Yeah, still the wrong way to do it, but at least that way you're using a more standard practice even if it's in an amateur way.
Sorry, but fiberglass should not be used on metal. And that is bodywork 101. You don't fiberglass metal. And fiberglassing the back? So you can't figure out what happened with a magnet from the outside? Yeah sorry, that's shade tree, flip-job crap right there. If you have to conceal your "work" on the backside and cover it with interior panels you're doing it 100% wrong.
You're not going to convince me otherwise either. It doesn't matter if it would solve the problem. It's dirty pool. You're just screwing the car and the eventual next owner.
They are adhesive pads used for sound deadening so the car doesn't sound like tin can when you close it. A lot different then using resin to bond fiberglass to metal. The problem comes from different expansion rates of 2 different materials on the same panel. Applying resin and glass to metal doesn't usually last very long.Not to stir it up further, but lots of modern cars have a fiberglass mat glued into high stress areas such as trunk lids and hoods where they know people will be putting pressure on them.
Seems to me that the door is already disassembled, why not just fixed it with the traditional hammer and dolly method? Work the high area first to releave the metal stress and then start bringing up the low. I don't know much about heating and cooling method, but I'm pretty sure if the dent is large enough that it put an "eyebrow" in the metal, all the heat in the world won't help until that metal has been tapped down.
They use it to make boats too, and on top of a substrate that absorbs resin it makes for a nice tight bond. Resin has 0 strength by itself and on top of metal there is very little mechanical bond. There's nowhere for that boundary layer of resin to go to. Now if you were talking about the adhesives and epoxies that are used along with mechanical fastening of some means, either welding or riveting it would make more sense. An encapsulated fiberglass structure over a frame ok, but as a sealer on metal I don't see it.Fiberglass is actually an isolater against corrosion, it is common practice to use it when two dissimilar metals are used together in the aircraft industry.
Fiberglass and metal together will cause no corrosion.
You are the first person that has ever said to me that metal and fiberglass do not mix.
