Tires and Shocks
A/MP
I'm switching from a Dana 44 to an 8 3/4. The Dana from a CJ5 is narrower than the 8 3/4 that I purchased. It's from an Abody. I was able to stuff a 10.5 DOT slick in the wheelwell with only minor frustration. The 8 3/4 although 2" longer has 3"wheel studs. I'll be using a ladder bar with coil overs. Any suggestion? I'm also installing mini tubs. Thanks
