tires for 75 duster
moparmade43
Hey guys, Ihave a 75 duster with a 340, with 15x7 police wheels. If i remember right, I have 225/65 15's on the front, and when i am turning shart when not moving fast, they rub the very bottom off the front fenders, anybody know what is the largest tire I can put on this car without rubbing opn the front?
Thanks
I had a similar problem on my 73 Duster........when I turned the wheels mostly to the right, the tire on the drivers side would barely rub the fender. After I had the restoration completed on it this past summer, I talked to my body man about the situation (after replacing the fender on the drivers side) that it was still going to rub.....so the only thing that I was able to do was to take the front fender brace and push it out a little when the wheels were turned to clear it. Not had a problem since with any rubbing. This was with P205\70R14 tires.
Hope that this helps.
Greg.......mtn_jake
