Dfnsmn34
Margarita Mike
Designed for high performance street 340-360 c.i.d. Chrysler V8s, this Torker II is a single-plane, low-rise design and delivers optimal performance in the 2500-6500 rpm range. It produces top-end gains with good throttle response and is ideal for high horsepower, high-performance street and bracket applications. The Torker II's low height makes it ideal for vehicles with limited hood clearance. Can be used on 318 c.i.d. if 340-360 c.i.d. cylinder heads are used. Not for heavy vehicles. Will not fit 1992 and later Magnum engines.
MSRP: $590.95
Price: $209.95
You Save: $381.00 (64 %)
In Stock
Item Number: 50761
http://store.edelbrock.com/50761intakemanifoldtorkeriichrysler340360polished.aspx
Found this while surfindaweb!
maybe someone can use it?
Aloha Mike
btw not mine....
MSRP: $590.95
Price: $209.95
In Stock
Item Number: 50761
Aloha Mike
btw not mine....
