[SOLD] torque converter,auto pedal,upper control arms
T-Man700
South Carolina
The converter was behind a "71 340ci and in front of a 727 trans., both were told had less than 700mi. on rebuilds. Also told it is a 2500 stall. The converter has many numbers stamped 141200,5935,1277,506 don't know brand, fluid clean and red,$100. Auto brake pedal from "72 dart $40. Upper control arms, small ball joints,$40 from same car. All plus ride from 45245.
Hi, T-Man700, thanks for the converter, I think it will work good for what I'm going to use it for. pleasure doing business with you. thanks, fabo, thanks again, 700, mike
