Anyone know the application for the different sized bolts?
BTW......I've got a ton of those TC and Flexplate bolts if you need any.How about......The little ones are TC bolts (TC to Flexplate), the ones on the right are flexplate to crank, and the middle ones are flywheel.
Left torque converter to flex plate. center are Flywheel to crank. right are flex plate to crank.
I'll throw a couple of the 5/16 TC bolts in the box. Looks like you have some real friends hereneed to find 2 more
The ones on the far right, can't see the head, look like oil pan drain plugs.
