Torque converter stuck! Need help!
Transmission and Drivetrain Tech
  1. Zach1720
    Zach1720 Member
    17
    1
    Mar 28, 2021
    St benedict pa
    Local Time:
    6:01 AM
    I installed a A904 tranny in my dart over the weekend. Car won't move in any gear after install ( fluid is full) making a whining noise when in park. A friend told me I probably didn't have the torque converter in all the way. I pulled the tranny back out only to discover that now the tc will not come out of the tranny. The question is could I have damaged the tc or the pump by not having it installed properly??? Why else would it be stuck? When engine and tranny are bolted together there is no gap between tc and flex plate. That made sense to me but I was told there should be a 1/4 inch gap Thanks in advance for the info.
  2. Kendog 170
    Kendog 170 Let the boy go !
    2,142
    1476
    Mar 10, 2016
    Tewksbury Ma.
    Local Time:
    6:01 AM
    Years ago I installed a torque convertor A904 only to discover it was the wrong one. Tranny guy who sold me it said bring it back and I'll give you the correct one :BangHead: . Car whined but would not move. Also ,you are suppose to push and spin the convertor until it drops in completely. Common error.
  3. RedFish
    RedFish Well-Known Member
    24,954
    3331
    Sep 5, 2007
    Local Time:
    5:01 AM
    Yeah If the torque converter is properly seated you should have to pull it forward a tad to bolt it up to flex plate. I never saw a converter stuck in a trans though. Good luck with it.
    • Agree Agree x 1
    • KickDown
      KickDown Just a Brit in Germany
      317
      156
      May 22, 2014
      Gifhorn, Germany
      Local Time:
      12:01 PM
      Sure sounds like the TC wasn't seated when the transmission was bolted to the engine.
      Here are 2 photos of a correctly seated TC in a 904.
      The second photo shows the measurement (in millimeters) from the starter ring gear to the bell housing flange.
      Hope it helps for future installation.
      • Like Like x 1
      • Zach1720
        Zach1720 Member
        17
        1
        Mar 28, 2021
        St benedict pa
        Local Time:
        6:01 AM
        Does anybody know why the tc would be stuck or if it may have damaged anything? Or will I be able to get it unstuck then position it correctly and put the thing back in?
      • Fawkes
        Fawkes Well-Known Member
        64
        46
        Sep 3, 2020
        Arkansas
        Local Time:
        5:01 AM
        Sometimes the torque converters are a tight fit into the trans. You might just have to gently pry it out, very carefully. With the TC in the trans, there should NOT be enough room to get your fingers on the backside of the TC. You can feel when the TC is engaged into the trans because there is a slight resistance when you spin it. It clicks and drops in several times before its actually seated.
        • Agree Agree x 2
        • RustyRatRod
          RustyRatRod I was born on a Monday. Not last Monday. FABO Gold Member
          71,784
          46972
          Jun 7, 2010
          Georgia
          Local Time:
          6:01 AM
          You answered your own question, Zach. It sounds like you didn't engage the converter all the way when you installed.
          Askin questions is good, but the converter's gotta come back out, so that's what has to happen before you can repair any damage. "However" you can get it out. I would use a length of chain bolted to the cross lugs on the converter and snatch it out with a slide hammer. You're not gonna hurt it further, because it's stuck. Whatever damage is done is already done. Any damage incurred by pulling it back out is a necessary evil.
          • Like Like x 2
          • Zach1720
            Zach1720 Member
            17
            1
            Mar 28, 2021
            St benedict pa
            Local Time:
            6:01 AM
            Thank you guys for the help. I will keep you updated!!
          • 67Dart273
            67Dart273 FABO Gold Member FABO Gold Member
            48,299
            16331
            Oct 14, 2010
            Idaho
            Local Time:
            3:01 AM
            Can you just put the trans on it's nose on some 2x4's and "bump?"
            • Like Like x 3
            • Zach1720
              Zach1720 Member
              17
              1
              Mar 28, 2021
              St benedict pa
              Local Time:
              6:01 AM
              Not sure I'm going to try making a puller. Does anybody know what size flex play to tc bolts are? 5/16 ?
            • rustycowll69
              rustycowll69 Well-Known Member
              2,455
              1197
              Feb 19, 2016
              Pacific northwest
              Local Time:
              3:01 AM
              sounds like the front pump and/or the converter is damaged. Had you searched for previous threads, you may have avoided this problem. If it's any comfort, you are not the first guy to make this mistake.
            • Zach1720
              Zach1720 Member
              17
              1
              Mar 28, 2021
              St benedict pa
              Local Time:
              6:01 AM
              Haha yeah... Sometimes we have to learn the hard way
            • Dicer
              Dicer Back Bone beats Wish Bone all the time. FABO Gold Member
              1,353
              1921
              Jan 12, 2016
              Land of Lincoln
              Local Time:
              5:01 AM
              Lay the transmission upward, converter towards the concrete, lift it a few inches and drop it flat on the floor.
            • rustycowll69
              2,455
              1197
              Feb 19, 2016
              Pacific northwest
              Local Time:
              3:01 AM
              I learned it when I was about 19yo. My late buddy, Art, was putting a turbo hydro 350 behind a 327 in an old Chevy van. I was helping him. We couldn't push the trans bellhousing up flush to the engine, so we used the BH bolts to draw it up. We had it almost drawn up when we heard a huge metallic "sprong". We looked at each other as if to say, "that didn't sound good." We pulled it back apart, and the front pump was broken.
              • Agree Agree x 1
              • pishta
                pishta I know I'm right....
                19,845
                9208
                Oct 13, 2004
                Tustin, CA
                Local Time:
                3:01 AM
                we did a trans install in the driveway and I said this doesnt look right. We dropped it down (on a floor jack with the tail still supported by a brick or something) and I turned the convertor a second time and it dropped deeper again. So I always turn it until it drops in twice now. Look into a convertors input and you can clearly see 2 sets of splines that need to both be engages as well as the converter hub fingers.
                • Like Like x 1
                • CudaFactHackJob
                  CudaFactHackJob FABO Gold Member FABO Gold Member
                  1,651
                  623
                  Mar 17, 2016
                  Hemet, Ca.
                  Local Time:
                  5:01 AM
                  You probably broke the ears off the pump. Then there was no lube going on and the front bushing welded itself to the converter. Now the bushing is stopping the converter from coming out when it contacts the front seal. Pry on both sides with some large offset wrenches and rip the bushing thru the seal.
                  • Like Like x 2
                  • 65TerrorCuda
                    65TerrorCuda Well-Known Member
                    386
                    45
                    Jul 26, 2009
                    Albuquerque, New Mexico
                    Local Time:
                    4:01 AM
                    What hack said. The bushing transfers metal to the converter shaft. Took two guys leaning on huge pry bars to wiggle the converter until it came out with the bushing attached. We stood the trans on the output shaft to do that. It sucked
