Torque Sequence
Joseph24251_200
The Mopar Kid
Fayetteville
Can some one give me the torque sequence to a sb engine 360 even thou all should be the same and any tricks or any thing you have to insureing a good seal thanks.
Start in the middle and work your way to the ends crossing over from the intake side to exhaust side each time. First time 25% of rated torque, then 75% then 100%. If you're using a clicker type torque wrench figure on a 5% override therefore if 100 ft/lbs is the target set wrench 105. Slow even pull on the torque wrench (no jerking) and remember to take your time. At least this is the way I do it. Almost forgot, use engine oil on the threads. I found a picture for BB's to give you an idea. http://www.moparts.com/Tech/Archive/bb/19.html
Terry
so I should be torqueing each bolt 3 times to a final of 100ft/lbs. I really was just double checkin the sequence I'm really just not sure of the final torque numbers now. Any suggestion on the final torque I should be going for
360 factory cast iron heads 95 ft/lbs.
Terry
