torque spec
I noticed that one doesn't have intake manifold specs, this one does.
Dodge Magnum Torque Specs
If you're using the factory intake manifold, neither of these have the specs (or the sequence) for the plenum plate.
can anyone tell me what this means
Harmonic Balancer bolt:
180 ft-lb. (Chrysler spec)
130 ft-lb. (what we use, your mileage may vary)
The actual torque spec for the harmonic balancer bolt is 180 ft lbs, but those guys have been going to 130 ft lbs with no problems. I usually just hit that bolt with an impact gun. Haha
