NiceFishEh
Hey guys
Need torque specs for timing cover and water pump bolts on my 340.
Thanks
Jim
Thanks
Jim
LA Engine Torque Specifications Small Block Chrysler 273, 318, 340, 360
* Torque values shown are in ft/lbs unless otherwise noted
* Follow factory torque sequence
Fastener Torque Thread Size
Camshaft Lockbolt 35 7/16-14
Carburetor to Manifold Nut 7 5/16-24
Clutch Housing Bolt 30 3/8-16
Connecting Rod Nut 45 3/8-24
Crankshaft Bolt (Vibration Damper) 135 3/4-16
Cylinder Head Bolt 273-318 85 1/2-13
Cylinder Head Bolt 340-360 95 1/2-13
Flywheel Cover Bolt 100 in/lbs 1/4-20
Flywheel Housing to Block Bolt 50
Flywheel to Crankshaft Bolt 55 7/16-20
Fuel Pump to Block 30 3/8-16
Intake Manifold Bolt 35 3/8-16
Main Bearing Cap Bolt 85 1/2-13
Oil Pan Drain Plug 20 1/2-20
Oil Pan Bolt 15 5/16-20
Oil Pump Cover Bolt 95 in/lbs 1/4-20
Oil Pump to Block Bolt 35 3/8-16
Rocker Shaft Bolt 30 3/8-16
Spark Plug 30 14mm
Timing Cover Bolt (cast) 30 3/8-16
Torque Converter to Flexplate Bolt 270 in/lbs 5/16-24
Vibration Damper Pulley Bolt 200 in/lbs 5/16-20
Water Pump to Block Bolt 30 3/8-16
Spark Plug 30 14mm
Handy list here
Per post #2 and #8 above, I believe the rocker shaft torque listed is incorrect (not 30 ft-lbs and not 3/8" bolts).
As I already stated/warned in post #4, the rocker shaft bolts are only 5/16" and factory torque spec is 200 inch-lbs.
