these numbers are straight out of my 71 chrysler manual
con rod nut - 45 ft lbs
cyl head bolts - 95 ft lbs
main bearing cap - 85 ft lbs
cam shaft lockbolt - 35 ft lbs
cam shaft thrust plate - 210 in lbs
crankshaft bolt - 100 ft lbs
intake manifold - 35 ft lbs
oil pump cover bolts - 95 in lbs
oil pump attaching bolts - 30 ft lbs
water pump - 30 ft lbs
think this is what ur looking for. hope this helps! again this is from a 71 book so idk if any other years are different
Note: If you are not using a factory fastener (ie new rods, or redone rods with new performance bolts) the torque will vary and you need to check with the manufacturer of the fastener. ARP has a section for torque specs for all their stuff. Also note all the values given above are for threads oiled with straight 30wt oil. If you are using some moly type lube the values may also be different.
