lhearold
OK, here is one for everyone. The FSM for the 69 Dart just says to install the torsion bars. Pretty vague in that it doesn't say how far into the LCA socket to put them. Do you bottom them out in the LCA socket? If you do, the rear hex is forward of the cross member in the rear anchor. If you keep the rear hex under the cross member then the torsion bar front hex is only into the LCA socket the distance of the hex.
Which is right??????
Larry
Larry
