I have a completely stock 1986 318/727 from a ram. I converted the ignition over to electronic with a Standard LX101 ignition control module and stock replacement vacuum advance distributor WPS brand, all for a 1975 318 from parts catalog.
Got everything hooked up and engine runs beautifully and starts up easy. Right now the initial timing is set at 7 degrees at 730rpm, set with vacuum advance plugged and the car in gear and my son's foot on the brake. Tried to check total in gear as well but couldn't get the car past 2200rpm in gear. Maybe due to the lock up converter, so I couldn't check total timing.
Now, with my dial timing light, and the car in park, I still got about 7 degrees initial, but I'm not seeing 34 degrees until around 3000rpm. And the weird thing is, it keeps advancing the more rpm I gave it. I think it was around 46 at 4000rpm.
I'm a little rusty on timing, but I thought once the distributor reached it's total mechanical advance the timing would stay at there for the rest of the engine rpm range. Why does mine keep rising? Is it normal because the engine is in neutral with no load? Or is it a distributor issue? Maybe the advance mechanism I'm my dizzy is broken or not secured correctl
