TPMS problem
ghamdimd
New Member
saudi
I have a Dodge Charger 2015 and it's a problem with tire compression, because at day it works and when the sunset it doesn't work and I changed all the sensors and re-programming and I don't know what the problem is.
Just a heads up. I had a neighbor who spent months chasing a tps problem in his toyota so he finally broke down and took it to a dealer and the first thing they did was check the spare tire. It was low... they filled it... problem solved.
Not saying this is your issue but it's worth checking
What exactly do you mean it works and it doesn't work ? Did you have any recent work done to the tires or wheels ?
The tpms light comes on or not ? It should tell you how much pressure is in each tire so know will know right away which one is low.
It only goes on when one of the tires is low on pressure.
Get/buy a tire gauge and fill tires to pressure shown on the drivers door jam.
You may have to drive a few miles for the monitors to reset.
