i run one on my 340 in the dart.nothing special...about 10:1 comp,j heads ,old crane hmv cam,2500 stall.ive run it with 390 holleys,500 afbs,and 450 holleys.the 450 work good but they need a loose converter to not bog.the 390 holleys worked the best for street driving .despite the "it will have no low end comments" it seems to spin the tires at a light stab.before the t ram i ran an rpm air gap,a torker ,and a weiand x-celerator.the ram made more power than all of them and only gave up a little low end compared to the air gap.
no apology needed.the "it will have no low end comments" were what people told me when i was toying with the idea of a t-ram.i was not referring to your post.actually ,you posted in support of my idea in in my t-ram thread irrc.sorry if i gave the impression that the TR5 is a "it will have no low end power" manifold,i know it isnt,i just tried to point out that the manifolds with tall plenums are rated for some pretty high rpm while the low plenum has a more sane designed rpmwindow where it works good.
and i pointed at the good midrange since that is where i think these manifolds realy shine compared to anything else i have tried,and the lowend is pretty good actualy pretty close to the airgap manfiold while the midrange and top has been outstanding on the tunnelram even if its hard to judge the diference up there in the higher range.
oh to the original poster if you end up not being satisfied with the taller plenum and have trouble finding the lower version dont worry there is lots of them out there bolted to smallblock chevy tunnelrams of the same type and they are the exact same part and fits perfect on edelbrocks smallblock mopar tunnelram base:cheers:
other than a valve job and good valve springs not much has been done,just some milling.as for linkage im running a lokar throttle cable and KD cable.my carbs are mounted in line and work 1:1.(not progressive).my cam is a much milder than what your running .it pulls hard from 2500 to 6000.its also ground on a 114 lsa helps idle quality as well as off idle transfer .i ran a more radical grind before on a 108.it hit like a sledge hammer in the mid range ,but my current set up is more street friendly with more of a "stump puller" torque curve.my point is it will run well with a smaller cam should you want a little more low rpm power.340 8bbl my motor will be around the same as yours but with some more compression and a higher stall. What do you have done to your J heads? I have a set of 360 J heads and im putting 2.02 intake and 1.6 exhaust valves in them. Forgot which cam im installing in it have it saved at my computer at home (out of town for work) but i believe its around .556 lift (belive sweet spot is 3400-6800ish) which is pretty much the same sweet spot as the TR-5 (3500-7000+ is what edelbrock told me when i called) So that should be a pretty good match correct?
